Perform this procedure to configure the remote hello multiplier to specify how many hellos the switch must miss before it considers the adjacency with a neighboring switch down.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure the level 1 hello multiplier:
    isis remote l1-hello-multiplier <1-600>
Configuring the remote hello multiplier on port 1/2:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface gigabitEthernet 1/2
Switch:1(config-if)#isis remote l1-hello-multiplier 1
The following table defines parameters for the isis remote l1-hello-multiplier command.
Variable Value
<1-600>
Configures the Level 1 hello multiplier. The default value is 3 seconds.
